Ok, finally got to it tonight... yeah it's been a while.
Is the clutch pushrod adjuster the long headless bolt that has a slit for a flathead screwdriver in it? My parts catalog is calling it a "Pin, thrust" and part no. 550047/e. If that's the case, I also think we got our vocabulary mixed up earlier tonight and rob-bot and I stripped that Hex Nut M6 (6mm?) which i believe is the lock nut. Thrust Pin is slightly stripped too, but we managed to get them back on enough so that the clutch works and the kickstart pedal works.
Weird thing we encountered with this thrust pin:
When it was screwed in til it lightly bottomed them backed out a half turn the kickstart pedal had very little resistance to it and wasn't kickable to start the bike. When I unscrewed it a lot, then the kickstart lever was almost locked up and immoveable. Screwed it in bit more, but not nearing bottomming out, then finangled the stripped nut back on there good enough to keep it in place and now the kickstart works and the clutch works. It's rideable again, but I fear we didn't do a proper job of clutch throwout adjustment.
Questions:
Is the "Thrust Pin" from the parts cat the same thing as the clutch pushrod screw?
Why does the thrust pin/pushrod screw impact the workability of the kickstart pedal?
Should we be replacing that stripped thrust pin and lock nut? Does that require removal of the gearbox cover, and is there anything else we need to look out for (such as springloaded ballbearings/etc)
Any other theories welcome!
Thanks in advance!
.... also if I don't reply obsessively it's because i have a new job now that doesn't permit constant enfield foruming. Will check back tomorrow night-
cheers all!
chuck
