Haha yes I have ridden the bike, prior to and after we did the cable change. Rob-Bot's just psyched the bike is rideable again after only 5 days of unbroken enfield ownership. It is a noticeable difference from my bike, and me being who i am I really just want to understand the thing. It seems unnecessarily hard to engage the clutch.
I'll try and get the info about changed springs from the previous owner.
Another point of note is that after we installed the cable we had to tighten it significantly at the gearbox end just to take up the slack (there was a ton of play in the clutch lever) and initially when riding it that way you couldn't get it into any gear besides first (without just forcing it at higher speeds, matched RPM's) figured it needed tightening, so I tightened (screwed Out) the clutch level barrel adjuster about as far as it'd go, and at that point the bike would shift fairly normally into gears. Still clunkier than my bike, and that difficult lever pull persisted like always. Like i said, rideable, but not ideal.
We're not going to go digging around in there til after he takes the MD bar exam he's been studying for but I'll also try and make sure the cable isn't pinched on anything. Maybe throw a little more lube down inside the housing just to make sure...
Now to research some more about throwout adjustment (i think that nut got messed with when the cover came off the gearbox hole.)
Thanks again!
Chuck
