March 2012
February 08, 2016, 09:45:42 pm
Author Topic: By-pass stop switch on side stand.  (Read 4857 times)
Portland Bullet
  • 2011 B5
Re: By-pass stop switch on side stand.
« Reply #30 on: July 26, 2013, 11:45:53 am »
I'm disconnecting that switch (having read here somewhere of a rider's bike cutting out because of it WHILE he was riding) - but fact is I never use the sidestand. Always the center stand. Looks so much nicer - though I think I don't quite have the weight/balance technique down to park it smoothly.
The Portland Bullet
To Dream, to Live, to Ride
2011 B5 Bullet 500cc
« Reply #31 on: July 26, 2013, 02:34:59 pm »
My bike would actually start and idle with the side stand down and leaning on it, but when you take the weight off, it would quit! I usually just parked it on the center stand and it ran fine from there.
I have seen guys crash when taking off with the side stand down. I've had some dicey moments in the old days before the switches were used.
dginfw
« Reply #32 on: July 26, 2013, 11:18:44 pm »
I've been way too lazy to get in there and find the wires, but if I ever get around to it I'll post up the wiring diagram...
I plan on using a relay to simulate the opening/closing of the switch in the 'sidestand up' position by triggering it with the neutral indicator feed wire. That way you could put the stand down IF the bike was in neutral, but if you put it in gear (thus turning the neutral light off) it would trip the relay and kill the engine. Just like most other modern bikes. Eventually I'll get around to it....I hope.  I've gotten pretty lazy in my middle-age
                    '12 C5 military -sold
                    '14 Continental GT-  sold
benknrobbers
  • Bohica
« Reply #33 on: July 26, 2013, 11:58:19 pm »
I rode every day for years on my last bike, and never had a problem with taking off with the stand down. it's just something you train your muscles to do without thinking.
Always prepare for the worst and your surprises will always be pleasant ones.
« Reply #34 on: July 27, 2013, 12:11:10 am »
+1
That's what I'm saying.  One scary left turn will make you TRIPLE check your side stand before every trip.
« Reply #35 on: July 27, 2013, 01:16:57 am »
+1
Mine always gets a double check heel tap before my left foot goes up to the shifter.  Your bike will not do a straight little hop if it hits!  Ugly, ugly, ugly.
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
« Reply #36 on: July 28, 2013, 12:47:04 pm »
For my 2010 G5 Deluxe (with the 19" Wheels) the stock stand was to short making it lean too far over. I also don't like Side Stand Switches, so both had to go. I found an old Kawasaki Stand on Ebay, & made it fit perfectly.
All just right now!  Photos below.
Best Wishes, Craig McClure
heloego
« Reply #37 on: July 31, 2013, 12:58:03 pm »
I dropped my bike 2" and it leans just about right !! ;D
Shouldn't it lean just about left?  ;)
hillntx
  • Shriner Bulleteer
  • 2011 C5 Classic
« Reply #38 on: August 02, 2013, 07:30:23 pm »
I've used the ground to kick up my side stand on various bikes over the years, never was really and issue.  My Honda with a safety switch pretty much trained that out of me.
Blairio
« Reply #39 on: August 03, 2013, 12:40:33 am »
My side stand switch acted up a couple of times - needing an extra nudge for the switch to break continuity and the engine fire up. Out of interest I dismantled the switch and found that the spring-loaded metal plunger that is actuated by the side stand passes through the switch body was bone-dry, with no lube.  a small smear of lithium grease did the trick, and the switch works smoothly now.
The switch plunger has a neoprene dust cover round it, to keep grease in and crap out.  Perhaps just add the switch to the list of things on the enfield that need checked, cleaned and lube'd on a regular basis? It isn't a big deal.
Cheers,
Blair
2012 Electra EFI Riviera Red
