Back country roads
32 Guests, 3 Users
ace.cafe, gizzo, baird4444
July 31, 2015, 06:05:47 am
Author Topic: By-pass stop switch on side stand.  (Read 4123 times)
drbvac
  • Low as it can go
« on: May 15, 2011, 04:17:08 pm »
Has anyone bypassed the cut-off on the side stand. Pretty hard to stop and kick down the stand and not shut off the motor but SOMETIMES it may be nice to be able to start the bike with it down - kick for example ::"" :-\
Dr B
t120rbullet
Re: By-pass stop switch on side stand.
« Reply #1 on: May 15, 2011, 05:03:57 pm »
Just disconnect it and you good to go.
GreenMachine
« Reply #2 on: May 15, 2011, 06:19:25 pm »
i think all your switches and sensors should have a  embedded MAC address that way if the CPU doesn't get a answer in the startup config file you u don't get a start....that will take care of you bypassing anything..serves you guys right for not staying old school with the rest of us... ;D :o
Oh Magoo you done it again
singhg5
« Reply #3 on: May 15, 2011, 06:32:42 pm »
RE in India sells 4 or 5 models of these 'new' bikes (UCE bikes) with carb. Still old school for the most part.  Only one model C500 is with ECU in India.
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
motomataya
« Reply #4 on: May 15, 2011, 06:39:05 pm »
Its easy to disconnect your side stand switch. It's also easy to end up as a hood ornament because you left your sidestand down.
« Reply #5 on: May 15, 2011, 08:20:35 pm »
+1.  I did this a while ago to eliminate it as a potential problem while debugging something.  I like being able to warm it up on the side stand to much I never put it back.  Keep in mind, you are disabling a safety feature.
holodeck
« Reply #6 on: May 15, 2011, 08:51:58 pm »
How exactly, do you disconnect it ?
r80rt
  • C5 Pilot
« Reply #7 on: May 15, 2011, 09:00:39 pm »
Follow the wires up the the coupler and unplug it.
Iron Butt Association
singhg5
« Reply #8 on: May 15, 2011, 09:05:32 pm »
There is a connector just above the side stand near the frame that connects side stand switch.  Unplug it.  Then wrap the connectors in tape or shrink tube to protect from dust.  Tie it to the frame with a twist tie.  Here is a picture -
1970's Jawa /  Yezdi
Andy
« Reply #9 on: May 15, 2011, 11:28:00 pm »
I never understood how people can drive away with it down.  Hop on, straighten up, and sidestand up.
I didn't mind my old Yamaha's switch which would shut off the engine when it was put in gear with the sidestand down, but to not let it start at all?  That's pointless.  Still, I left it connected for a while.
Then one day I couldn't get it started.  I gave the sidestand the slightest of upward pushes, and it fired right up.  I disconnected the damn thing the next day.  If it's going to "save me" when the stand isn't even down, I don't want it at all, especially if it's going to activate intermittently on some bumpy road somewhere.
2010 C5 Military - "The Slug"
« Reply #10 on: May 15, 2011, 11:42:52 pm »
I grew up with out safety switches.
 Forgetting to put the stand up when taking off or down when parking resulted in a lesson learned,,,,once. ;)
REA #136
REpozer
  • Superfly and
« Reply #11 on: May 15, 2011, 11:52:50 pm »
I've never owned a motorcycle that had a safety sidestand switch, or a clutch safety .
I have never forgot to put the side stand up ...yet either.
REA # 84 ( the first time)
« Reply #12 on: May 16, 2011, 12:01:17 am »
My Ducati was the same and I thought it a good idea.  This way you can warm it up on the sidestand but still won't ride away with it down.
r80rt
  • C5 Pilot
« Reply #13 on: May 16, 2011, 07:31:24 am »
Yep. me too.
« Reply #14 on: May 16, 2011, 12:05:32 pm »
     Sometimes I feel like everybody out there now is suffocating by being buried in "safety switches" in all aspects of life. Kids are afraid of EVerything nowadays 'cause the government & the schools & their parents tell them to be. I survived my whole life with my safety switches almost all internal to my brain & the first thing that came off the Enfield was that that silly kickstand switch. Next was the headlight jumper. I'm not disturbed by the clutch switch (yet). I don't use the electric start.
2008 ACE Head AVL Classic
drbvac
  • Low as it can go
« Reply #15 on: May 16, 2011, 04:19:27 pm »
Glad its not just me - never had a bike with one and pretty hard to drive with it down - now if it folded up the other way it might make a mess  ???
Dr B
holodeck
« Reply #16 on: May 16, 2011, 04:30:59 pm »
 Disconnect the lawyers and the world would be a much better place.
olhogrider
  • Black C5
  • 2012 C5
« Reply #17 on: May 16, 2011, 08:16:30 pm »
Harley's patented Jiffy Stand will retract itself if you ride off with it down but is locked in place weight on the stand. Japanese bikes used to come with a rubber strip pointed at the ground that would drag and retract the stand.
After disconnecting the switch I rode off with mine down. I had parked on the side stand but put it on the center stand for fueling. I reconnected the switch after that. Probably would never do that again but I might.
GreenMachine
« Reply #18 on: May 16, 2011, 08:25:11 pm »
I've left with my aftermarket side stand down..no big deal as the scraping sound tells it all...probably did it three times over a 4 year period...it's that moment when u say, what the hell was i thinking...if anything its more embarrassing if someone was watching....
« Reply #19 on: May 17, 2011, 09:36:04 am »
Some of the Ducati super bikes have a side stand that retracts as soon as you tilt the bike up.  Great for riding safety, not so great for the parking lot browser casually sitting on bikes when he goes to put it back.  There's a nice aftermarket eliminator for this.
« Reply #20 on: May 17, 2011, 01:55:45 pm »
I had a Ducati 900SS that got that alternare spring mounting attachment as soon as I got the bike, caused by a much earlier experience with a Bultaco Matador with the handy spring loaded side stand. I went into a gas station and as I got a bit close to the pump, I shoved the side stand down, but had to get off on the right. As I did that, I pulled the bike up a bit, then let go of it so it would drop back onto the side stand. It dropped into the pump! Fortunately, no damage, other than to my ego. Don't like those spring loaded things. Also had a Yamaha Fazer that the side stand switch would cut out, especially coming off a stop light when you were about half way across the street. I found the just a little kick on the side stand would reset it. I finally cleaned it with some contact cleaner and never had any more problems with it.  And I have forgotten to put the stand up on a few occasions in the last 50 years. A loud scraping noise joins with a bit of an embarrassing wobble. My issue with the Bullet side stand is that it's too short and lets the bike lean over too far. I tried to find one of the adjustable ones, but they are apparently amongst the unobanium bits, so I guess it will be off to the hacksaw and welding torch. Or I'll just live with it.
« Reply #21 on: May 17, 2011, 02:45:12 pm »
It does lean a fair bit but it's not unstable.
drbvac
  • Low as it can go
« Reply #22 on: May 17, 2011, 03:11:51 pm »
I dropped my bike 2" and it leans just about right !! ;D
Dr B
Desi Bike
« Reply #23 on: May 17, 2011, 04:55:56 pm »
A swift wack on the side of the head with a tire iron?
میں نہیں چاہتا کہ ایک اچار
GSS
« Reply #24 on: May 17, 2011, 07:03:40 pm »
I removed the two Allen head screws at the side stand to pull off the switch last month......took all of one minute.....one less thing to troubleshoot in the future!
« Last Edit: June 11, 2011, 07:40:57 am by GSS »
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
Philbomoog
« Reply #25 on: May 18, 2011, 10:53:00 am »
I removed my side stand switch about 8000 miles ago.
Just out of curiosity I sat on a Harley in a dealers a while back, not realising that the side stand would automatically retract itself. Having amused myself for a couple of minutes I started to get off the bike only to have the wee  beastie fall over and nearly break my leg.
I managed to recover the situation without anyone noticing. ;D
blueberry
« Reply #26 on: May 18, 2011, 11:27:45 am »
Whats next? A motorcycle that parks itself?
Ride Safe, Blueberry
2008 Electra
1985 Honda 250 Rebel
1970 Honda SL90
olhogrider
  • Black C5
  • 2012 C5
« Reply #27 on: May 18, 2011, 01:13:52 pm »
I did the same thing at the BMW dealer. Dropped it on the floor! The dealer simply smiled and pointed out how effective the engine guards are.
Lady_Enfield
  • Bluce
« Reply #28 on: May 18, 2011, 03:03:19 pm »
Officially disengaged today.  The side stand switch not me.  8)
I am Multi-FUNctional!
T Bird
  • Tracy P
« Reply #29 on: July 26, 2013, 04:42:57 am »
I couldn't agree more! Had the bike just two days and the only thing that really bugs me is this stupid switch! I really want to be able to kick start it and I always did my old Bonnie on the side stand!
I am more worried that I'll start it up and while letting it warm up, go to put it back on the side stand that won't be there!! I will be disconnecting it very shortly!
In 31 years of riding I think I've ridden off once with it down and got shouted at that it was. Didn't catch in the ground so got away with it. If it was like the new Triumph's and cut out if you put it in gear with it down, then that would be fine but no start in neutral?!? Just daft!  ::)
I've defected! Don't tell the Triumph Owner's MCC!
Portland Bullet
  • 2011 B5
« Reply #30 on: July 26, 2013, 11:45:53 am »
I'm disconnecting that switch (having read here somewhere of a rider's bike cutting out because of it WHILE he was riding) - but fact is I never use the sidestand. Always the center stand. Looks so much nicer - though I think I don't quite have the weight/balance technique down to park it smoothly.
The Portland Bullet
To Dream, to Live, to Ride
2011 B5 Bullet 500cc
« Reply #31 on: July 26, 2013, 02:34:59 pm »
My bike would actually start and idle with the side stand down and leaning on it, but when you take the weight off, it would quit! I usually just parked it on the center stand and it ran fine from there.
I have seen guys crash when taking off with the side stand down. I've had some dicey moments in the old days before the switches were used.
dginfw
« Reply #32 on: July 26, 2013, 11:18:44 pm »
I've been way too lazy to get in there and find the wires, but if I ever get around to it I'll post up the wiring diagram...
I plan on using a relay to simulate the opening/closing of the switch in the 'sidestand up' position by triggering it with the neutral indicator feed wire. That way you could put the stand down IF the bike was in neutral, but if you put it in gear (thus turning the neutral light off) it would trip the relay and kill the engine. Just like most other modern bikes. Eventually I'll get around to it....I hope.  I've gotten pretty lazy in my middle-age
Dave in TX:   '01  W650
                    '14 Continental GT-  sold
                    '06 Iron Barrel Bullet
benknrobbers
  • Bohica
« Reply #33 on: July 26, 2013, 11:58:19 pm »
I rode every day for years on my last bike, and never had a problem with taking off with the stand down. it's just something you train your muscles to do without thinking.
Always prepare for the worst and your surprises will always be pleasant ones.
« Reply #34 on: July 27, 2013, 12:11:10 am »
+1
That's what I'm saying.  One scary left turn will make you TRIPLE check your side stand before every trip.
D the D
« Reply #35 on: July 27, 2013, 01:16:57 am »
+1
Mine always gets a double check heel tap before my left foot goes up to the shifter.  Your bike will not do a straight little hop if it hits!  Ugly, ugly, ugly.
1975 XLCH
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
« Reply #36 on: July 28, 2013, 12:47:04 pm »
For my 2010 G5 Deluxe (with the 19" Wheels) the stock stand was to short making it lean too far over. I also don't like Side Stand Switches, so both had to go. I found an old Kawasaki Stand on Ebay, & made it fit perfectly.
All just right now!  Photos below.
Best Wishes, Craig McClure
heloego
« Reply #37 on: July 31, 2013, 12:58:03 pm »
Shouldn't it lean just about left?  ;)
hillntx
  • Shriner Bulleteer
  • 2011 C5 Classic
« Reply #38 on: August 02, 2013, 07:30:23 pm »
I've used the ground to kick up my side stand on various bikes over the years, never was really and issue.  My Honda with a safety switch pretty much trained that out of me.
Blairio
« Reply #39 on: August 03, 2013, 12:40:33 am »
My side stand switch acted up a couple of times - needing an extra nudge for the switch to break continuity and the engine fire up. Out of interest I dismantled the switch and found that the spring-loaded metal plunger that is actuated by the side stand passes through the switch body was bone-dry, with no lube.  a small smear of lithium grease did the trick, and the switch works smoothly now.
The switch plunger has a neoprene dust cover round it, to keep grease in and crap out.  Perhaps just add the switch to the list of things on the enfield that need checked, cleaned and lube'd on a regular basis? It isn't a big deal.
Cheers,
Blair
2012 Electra EFI Riviera Red
1954 Francis Barnett Falcon 70
