I built up a 1978 Ford Bronco back in the early 90's as a show and go 4x4. The engine was sparked by a MSD 6AL ignition control box. The high intensity multiple spark discharge per fire of the plug really burned the excessive amount of fuel the 400cu engine would use turning 39 inch tall tires. The power increase was noticeable for sure over the standard points ignition. One really neat thing the MSD boxes have is user settable rev limits... I'd plug in the 700rpm chip when I'd park it for shows, if someone wanted to start the thing and steal the vehicle, it would only idle and even then it wasn't enough get the auto transmission to hook up enough to drive, low budget security system haha.
With my random poking around on the internet I was surprised to see that MSD has a single cylinder motorcycle box available. The price is a bit steep, but from my experience with the 6AL in the Bronco I'm wondering if it would be worth the money. Summit Racing has it on for $540 or so.
http://www.msdignition.com/instructions/Products/4223.pdf?terms=mc3Here's a question... is the UCE a capacitive discharge system for ignition, if so then it doesn't appear it would work with them.
Overkill for a RE perhaps?
Anyone..... anyone....Bueller?
