'08 Bullet mods
26 Guests, 3 Users
PerazziMx14, Nixie, Andrew69
February 10, 2016, 05:01:28 am
Author Topic: Spark Plugs - Projected, Non Projected, Dual electrode  (Read 5929 times)
Re: Spark Plugs - Projected, Non Projected, Dual electrode
« Reply #30 on: June 10, 2011, 09:14:31 pm »
I'm sure that the ceramic center electrode support is what he is speaking of and yes, a very light tan to a darker tan is good.
Before installing the NGK plug in my bike I had noticed not only some stalling at stop lights but while just cruising along at 45 mph there would be a mis-fire that lasted maybe 1/2 - 3/4 of a second.  This was happening about every 1/2 mile.
After replacing the plug I have never had another mis-fire like that. :)
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
« Reply #31 on: June 11, 2011, 12:18:12 am »
Ok thanks.. Looks like I'll have to try one of these plugs too! Any negatives on the swap?
« Reply #32 on: June 11, 2011, 01:11:37 am »
As I recall, the NGK BPR6ES came gapped at .030 rather than the .028 recommended in the UCE manual.  No problem as this NGK plug has an easily bent electrode.
It also has a screw on cap that I removed to allow it to mate with the existing high tension wire.
You probably already know it is a good thing to apply some dielectric grease to the ceramic insulator above the steel body and some anti-seize on the plugs threads is highly recommended.  Don't get this anti-seize on the gasketed surface as it does not conduct electricity well.
As I recall, the torque for the spark plug is 20 lb/ft.
WillW
« Reply #33 on: June 11, 2011, 02:10:50 am »
@ Sub - Yes that's what I meant. And the electrode.
Sub
  • Bob's Your Uncle
« Reply #34 on: July 01, 2011, 09:16:06 am »
FWIW, I changed to a NGK BPR6ES and many of the hiccuping and off-on throttle quibbles are gone.. Its definitely a noticeable improvement on my bike (air intake and efi exhaust). The bike also feels a bit smoother, and maybe even a bit quicker, although at the HP of this bike, who can really tell. :)
Here is my old plug, does it look ok? I'm including two pics because its hard to capture the tip color.. its light in color.. maybe a shade towards brown/gray. Am I a bit lean?
Okie Enfield
  • RED 2010 C5
« Reply #35 on: July 01, 2011, 10:57:01 am »
Looks lean to me. Of course with the air box mod youve made with the exhaust you were running, would be suprised if you werent a little lean. I will be looking forward to seeing the NGK after 300 miles or so, glad to hear your having the same good results with them that I and most who installed them are experencing.
prof_stack
« Reply #36 on: July 01, 2011, 12:04:09 pm »
+1
« Reply #37 on: July 01, 2011, 12:28:47 pm »
... Of course the ULTIMATE plug would be a surface gap one .....
Do they still make those things. They worked pretty miserably in anything I ever saw them in. '70s Kawasakis, specifically. They always struck me that they were too cold. The Kwackers ran much better on conventional plugs.
The reason airplanes use dual electrode plugs is because the comparatively low voltage of the circa 1920 magneto ignition. They won't knock off minor soot-type fouling, so they have to bypass it...hopefully. Any modern EFI ignition supplies much more voltage that can blow past minor fouling attempts in the cylinder.
P.Schraub...Haven't you ever had to clear a fouled plug in your Cessna One-Filthy?
