Spot #3
May 24, 2016, 04:40:21 pm
Author Topic: Spark Plugs - Projected, Non Projected, Dual electrode  (Read 6406 times)
Re: Spark Plugs - Projected, Non Projected, Dual electrode
« Reply #16 on: May 30, 2011, 06:38:05 pm »
A few days ago I mentioned on the forum that when I was riding my new G5 at a smooth 45 mph occasionally the engine would mis-fire, like it suddenly wasn't getting a spark.  Nothing serious but an annoyance to say the least.
Another member said it was the Indian spark plug the bike comes with so with this in mind I did some digging.
Several posts mentioned the NGK BPR6ES plug so I went to my local auto supply and they had some of them.
After gapping it to .028 I installed it using my torque wrench set to 20 ft/lbs.
Today I rode the same route that I rode when I noticed the misfire and it ran perfectly.
In addition, the falling idle speed and dieing at a stop light has disappeared.  If anything the new idle speed is fast enough to make me think about adjusting it down a bit.
So far I'm a happy biker.  :)
« Last Edit: May 30, 2011, 08:41:32 pm by Arizoni »
GSS
« Reply #17 on: May 30, 2011, 07:32:48 pm »
Great choice. I saw the same improvements when I went from OEM to NGK plugs.
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
WillW
« Reply #18 on: May 31, 2011, 02:10:45 am »
  + 1
prof_stack
« Reply #19 on: June 04, 2011, 09:21:50 pm »
Scroll to the right to see the OEM (rich mix) plug.
I installed the NGK BPR6ES today.  With a little grease on the threads it hand tightened smooth as can be.  The OEM Bosch R6 plug was rough to get out with ratchet and plug socket.
The black Bosch tip verifies what the dyno test read regarding the air/fuel mixture.  Would a hotter plug be a better thing to have in there?
A ride to the dealer and around the area seemed to verify what Arizoni said about the idle being a little higher and not prone to have the motor stall.  At $3 a pop, I could change the plug more frequently.
« Last Edit: June 04, 2011, 09:31:33 pm by prof_stack »
« Reply #20 on: June 04, 2011, 09:26:28 pm »
I've been running that plug for quite a while now, it does very good for me. Get a tube of anti seize compound for your threads it's good stuff.
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
« Reply #21 on: June 04, 2011, 11:17:53 pm »
Has anyone done dyno tests between the plugs discussed here?
I'm tempted to try the ngk plug because I did have some running issues when I had my free flowing exhaust on from nfield (which Enfield says should have worked fine). I blamed it on the exhaust and a narrow ECU tuning range, but hey, maybe it was the plug!
« Reply #22 on: June 05, 2011, 12:09:04 am »
Some greases tend to cook off at temperatures around 250 degree F while some of the special wheel bearing greases can go up to 380 degrees F.
The spark plug in an air cooled engine gets hotter than 250 degrees.
 Without knowing exactly which grease you used you could be fine or the grease might cause a removal problem.
The Anti-Seize stuff is good to higher temperatures and it doesn't cost a lot.  Next time you buy a spark plug you might want to get a small tube if it.
A little goes a loooooong way.
When your applying Anti-Sieze apply it to the threads only.  You want a bare metal to metal contact between the spark plug, the gasket and the cylinder head.
As for the Dyno test, your engine was running at max power and although I have no idea what the computer mapping on a RE is, max power usually requires rich mixtures so I would guess that is what your bike was getting during the test.
Unless you plan on running your bike at its limits I would hold off on getting a hotter spark plug.
Run the new plug for a while and then check its color.  I'm betting it's just about right for daily riding.
prof_stack
« Reply #23 on: June 05, 2011, 08:15:40 pm »
Thanks for the tip.  I bought some anti-seize stuff today along with another new plug for whenever I change it next.  After 110 miles it is starting to get some rich blackness around the sides but okay in the middle.  Check out the photo.  See what you think.  On the right is the OEM Bosch.
WillW
« Reply #24 on: June 06, 2011, 02:07:09 am »
My plug gets black like that round the rim and the first couple of threads, so do the plugs on the other bike. I'm told by those who seem to know that this is fine as long as the business part is a nice tan colour, which it is.
« Reply #25 on: June 10, 2011, 01:39:32 pm »
I get the same.  Black on the ring, tip and electrode are tan.  All good.
At 6000 miles I just swapped to an NGK BPR6EIX gapped to 0.7mm.  Only one ride to work on it so far, seems about the same to me as the OEM Bosch plug.  I'll keep y'all posted.  Even if it's no better or worse, nice to have alternatives.
WillW
« Reply #26 on: June 10, 2011, 01:53:38 pm »
I noticed a real difference when I fitted that plug last year - much better starting, hot & cold. I also thought the engine ran smoother generally, and certainly idled better.
I've since replaced the standard NGK plugs in the Kawa with Iridiums, but can't say I've noticed any difference.
Could be the stock plug in the Enfield was dodgy......
NGK  -  good plugs.
« Reply #27 on: June 10, 2011, 03:52:55 pm »
Feels about the same to me so maybe your original plug was dodgey.  I'll report more after it's been in a while.
prof_stack
« Reply #28 on: June 10, 2011, 05:30:35 pm »
Feels about the same to me so maybe your original plug was dodgey.  I'll report more after it's been in a while.  Scott
The only thing I noticed so far is a more consistent idle with none of the trailing off and stalling stff at a traffic light I was used to with the OEM plug.
Sub
  • Bob's Your Uncle
« Reply #29 on: June 10, 2011, 07:57:32 pm »
Will, you mean the white part in the middle? I heard it should be a nice light to medium tan color.
