Peace of Mind
February 06, 2016, 07:59:30 am
Author Topic: Spark Plugs - Projected, Non Projected, Dual electrode  (Read 5885 times)
« on: May 10, 2011, 09:45:56 am »
In UCE EFI bikes, different kinds of spark plugs have been used, tested, discussed but I had not seen a real comparison of how deep they are inside the cylinder - which will determine the location of spark above the piston. If it is too close to piston, it will act as timing is too advanced and too far away from piston it will feel like the timing is retarded. That can affect the engine performance and likelyhood of piston damage.
UCE EFI bikes are originally fitted with Bosch WD7 DDC4 spark plug with Dual Electrodes which are on either side of the central electrode. Took this picture to compare the lengths of NGK Non-Projected (B8ES) and Projected (BPR 6ES) spark plugs with the Bosch plug.
Non-projected tip is clearly shorter and projected tip is slightly longer than Bosch plug.
« Last Edit: May 10, 2011, 11:12:25 am by singhg5 »
Re: Spark Plugs - Projected, Non Projected, Dual electrode
« Reply #1 on: May 10, 2011, 11:48:23 am »
It's not just depth/distance from the piston that matters.  You'll notice in the two plugs on the right that the electrode is more exposed.
Found this:
http://www.ngk.com.au/sparkplug_tech.php
It explains many of the common aspects of spark plugs including projection:
"A projected spark plug protrudes into the combustion chamber further and provides higher ignitability and improved performance. Simply this can be understood by representing the combustion chamber as a circle. A projected spark plug in effect produces a spark in the middle of the circle (or combustion chamber) allowing for an even flame spread. Conversely, a non-projected spark plug means the flame spread is not even."
It also explains the precious metal electrode nicely.  Since it has a higher melting point it can be narrower and again, gives you a cleaner, more precise spark resulting in better performance, whiter whites, britghter colors, and world peace :)  I think at least one user noted better performance (notably more stable idle IIRC) with a precious metal plug.
« Last Edit: May 10, 2011, 12:01:06 pm by Ducati Scotty »
jjoe256
« Reply #2 on: May 10, 2011, 04:18:30 pm »
   I pulled my original plug to see how it looked after 1 tank at TPS .724
My NGKBR6ES looks like the right side picture of the middle two optimal heat range:
http://www.ngk.com.au/sparkplug_tech.php#
jjoe256
« Reply #3 on: May 10, 2011, 04:28:42 pm »
     Aahh if only that were true.
« Reply #4 on: May 10, 2011, 04:52:24 pm »
I said one user, not you ;)
Tecomakeith
« Reply #5 on: May 10, 2011, 05:51:38 pm »
I have put in a Iridium plug in my C5 about 3000 klm's back and it works fine. It supposedly last about 100,000klm's and by that time I'll be to old to ride.
P. Schraub
« Reply #6 on: May 10, 2011, 09:23:02 pm »
Hey Folks,
        I run Bosch dual electrode plugs in my Enfield and my 79" Harley Shovelhead. I also run dual electrode plugs in my Cessna 150. As far as I know, all air cooled aircraft engines run dual electrode plugs for reliability. That's good enough reason for me to use them in my motorcycles. Just my opinion !
GSS
« Reply #7 on: May 10, 2011, 09:48:33 pm »
Recapping my experience:
New bike 0-300 miles Bosch WD7 DDC4 - occasional stalling on idle, bit of rough starting (probably just a "tight" engine), but electrode color looked good.
300-600 miles Iridium NGK BR8EIX - synthetic oil, great starting and idle, and electrode came out as expected with a thin layer of fluffy carbon.
600-800+ miles Iridium NGK BPR6EIX - another synthetic oil change, great idle and running, starting is a bit flaky but no stalls........I can almost feel slightly better acceleration (or maybe the engine is simply more broken in) :)
Great bike....snow is gone...85 degrees outside.....
« Last Edit: June 10, 2011, 06:46:19 pm by GSS »
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
« Reply #8 on: May 11, 2011, 09:37:04 am »
Hey Folks,
And a GOOD opinion it is! The REASON that these particular plugs were chosen is the fact that the flame kernel is not occluded by the ground electrode - the same reason they are used in aircraft engines, where a single misfire could have dramatic consequences. Using a projected tip plug WILL get the flame kernel started down in the "sweet spot" of the reactible gas in the chamber (Henry Yunick patented them for just that reason ...) I have found that if the heat range is correct for the mixture that you are running, the single electrode plugs are just fine. The ONLY difference that i found was in the hot starting - it usually took a couple more cranks (literally two ...) to fire the lean-ass mixture in the hole with the single electrode plug .... but that's ALL.
Jjoe 226 has it right with his ..... they are PERFECT as for what they should be .... Of course the ULTIMATE plug would be a surface gap one .....  ::)
ROVERMAN
« Reply #9 on: May 11, 2011, 10:31:55 am »
Scooter Bob is showing his deeply technical side. ;D ;D ;D
jjoe256
« Reply #10 on: May 11, 2011, 11:49:32 am »
  I meant world peace, etc.
« Reply #11 on: May 11, 2011, 11:52:37 am »
 ;D
jjoe256
« Reply #12 on: May 11, 2011, 11:54:48 am »
   I figured out my hot starting. Using the kick start, which I normally do, I ease past 1 TDC and the bike fires first kick. Cold start, with "choke", 2 eases and first kick fires. Every time. NGK BR6ES
« Last Edit: May 11, 2011, 11:59:07 am by jjoe256 »
« Reply #13 on: May 11, 2011, 04:14:15 pm »
Half a hour ago, I couldn't even SPAIL Muh-Kanick ..... Now I are one!  ::)   ;)   ;D ;D ;D
csbdr
« Reply #14 on: May 12, 2011, 09:36:01 am »
You slept at a Holiday Inn Express last night didn't you?
