FWIW, I've had mine off several times and have not needed any special tools. I also used the in "in gear" method to keep the crank from turning so I could loosen the nut holding everything on. - I had to actually set it on the ground, if I remember right, while sitting on it to get it to break though.
The three flat head allen machine screws holding the inner on are notorious for stripping out (the head, not the threads in the case). I have had to drill the screw out with 1/4 drill bit and replace twice. So, if you are ordering parts, have them send a few just for the hell of it. Like was mentioned, get the correct hex attachement for a ratchet - 5mm or 6mm, can't remember.
Clutch hub came off with slow patient gentle tapping and pulling.
Good luck with it.
aleman
