Instruments
18 Guests, 4 Users
finbullet, wildbill, krusty, L4V
April 30, 2016, 12:20:11 am
Author Topic: electrics  (Read 1429 times)
nellsr500
electrics
« on: February 17, 2008, 02:37:36 pm »
Hi   when I take the battery off and charge i get a full battery reading ...when I put it back on the bike I get a 9 volt reading ... any idea where the drain could be going to..cheers
ride free and be lucky
Nell
Wolverhampton, England
Re: electrics
« Reply #1 on: February 18, 2008, 02:46:46 am »
Are you saying that with the battery in the bike, but not connected although fully charged you get about 12. 4 volts (on a digital volt meter) then when you connect up it gives 9 volts? If so, that is a mighty discharge and you would see the terminal 'flash' as you connected the battery (ie a short to earth/frame) somewhere.
A bit more info required. Year of bike. Battery age. ES model or kicker only etc etc Might just be a duff battery but ????????
nellsr500
Re: electrics
« Reply #2 on: February 18, 2008, 11:50:22 am »
hi...its a 1991 350 bullet kickstart model...I dont get a flash or burn smell......built chops for years..but cant suss this out
Nell
