Military at the Airport
26 Guests, 3 Users
KenKZN, KD5ITM, Arizoni
February 10, 2016, 10:50:03 pm
Author Topic: Will I be comfortable on a new RE?  (Read 1702 times)
olhogrider
  • Black C5
  • 2012 C5
Re: Will I be comfortable on a new RE?
« Reply #15 on: April 22, 2011, 10:16:02 am »
Hard to say since the first time I saw it was when it broke but the pigtail was between the battery and the cable. The cable end is shaped to fit the battery, not a pigtail.  I suspect this put  undo stress on the cable terminal. If I reinstall the pigtail it will go under the bolt,  outboard from the cable end. The tiny terminal looks like it was simply pulled on until it failed. The replacement is a bullet-type (pun intended). Probably a better choice for an RE anyway.  ;)
