So the tappet cover on a friend's '09 AVL Classic has developed a neat little crack running from the acorn nut down to the bottom edge (which we discovered after trying to solve that leak with a new gasket). For an interim fix, we're either going to JB-Weld the crack neatly, or epoxy an inner-tube gasket to the inner face of the cover to prevent oil from reaching the crack.
As a more permanent fix, of course, he's looking to replace the tappet cover. He spotted one at bulletwala, but the part number doesn't match what he'd found in his looking around. Does anyone know if the AVL 350 tappet cover is physically the same as the 500's cover, just with a different part number?
