Here's their site... from what I've gathered, these 'battery tender' brand ones are the best, or at least there are no qualms so that's the way I'm going to go....
http://batterytender.com/motorcycle.htmlour RE batteries are about 12 v i believe so i'm prob going to go with that first option (Battery Tender Jr 12v).
On the other hand, my bike is always parked outside as I don't have a garage. it's always under it's tarp (nylon bike cover) but for that reason should I spring for the more expensive 'waterproof' battery tender?
Cheaper is better in my eyes, and i guess i could just not hook it up if it's supposed to rain...
Anyone have suggestions from personal use?
Also, if i would just let this battery die then spring for a sealed battery, do they not require a trickle charging every once in a while? Most of my riding is long range, at least an hour to two at a time, but the winter months will be another story...
Thanks in advance, Enfield Guru's-
chuck
