Reply #36 on: April 19, 2011, 09:12:20 pm
You also have to install a single fire ignition system.
And I still don't understand, after reading all these posts, why someone would want to have two coils on a single cylinder engine. Just for "looks"? What if someone who knows engines asks "What's the second coil for"?
At least there's a "Reason" to do it on a harley.
Isn't two coils on an Enfield sorta like tits on a suitcase?
No big deal, but this IS what you wrote,no mention of plugs here. I'd like to add for the original poster that they make plug wires now that will fire 2 plugs off of one coil. One plug is fired directly while the other is fired inductivly from a coil that is surrounding the wire. Put them on a harley (with dual plugged heads)and they seemed to work well. No extra coils needed. I think we got them from drag specialties or one of them outlets.
« Last Edit: April 19, 2011, 09:20:55 pm by cyrusb »
Logged
