This might sound obvious but it's worth a mention.
The clutch cable adjuster, either at the lever or, if you have it, mid-way along the cable, is just that - a cable adjuster.
The adjuster in the garbox housing adjusts the clutch itself.
They are two totally different things. If your clutch worked OK before the bar change then it'll work OK after if you have a long enough cable and it's not kinked or stretched. The cable might need some slight adjustment at the lever but other than that hand check the cable run for sharp kinks or stretches.
