Ace...some of us are still of that mind set...I'm not a 100% certified tear it apart mechanic...But I'm still a quick study. What I can't do I turn over to "trusted" professional. By the way...the Air Can arrived yesterday...anything specific i need to know before I install it?
You take off the existing stock airbox completely.
Take off the bottom wing nut from the canister and remove the bracket.
The bracket for the canister bolts to the same frame lug bolt that the old airbox mount bolted to. You might have to tweak the bracket a little, to get the canister to sit level, but it shouldn't require much tweaking. The frame lug positions vary a small bit from bike to bike.
Then put the stud on the bottom of the canister back into the hole in the bracket that it came out of when you removed it.
Then just stretch/push the connector hose over the carb mouth, and tighten the clamp.
Put the wing nut back on the bottom.
Tweak/twist/bend as necessary to get the thing to sit as level as you can get it.
Put the dry-transfer ACE sticker on it where you like it.
To change filters, just remove the canister, and take off the wing nut and hex nut, and it comes off the bottom.
There should be no need to ever take off the top. The wing nut on the top just holds the lid on.
All the maintenance activity is done on the bottom only.
Spare filters are available at AutoZone for about $5 in the Spectre Performance products section of the store.
