wasn;t this the original problem a while back..u get to the point as a consumer , where part replacement is synonymous to I'm not sure what the problem is or i don;t really understand how to fix the problem or combination of both.. granted, the balls in their court as its under warranty...Right? If it was my bike, i would check the battery first, fuel system second , coil output, and electrical associated with maintaining spark and battery replenishment third..generic terms here but a bike that starts and just dies going down the road after 5-10 min should be able to be fixed in a reasonable amount of time unless its heat related ....wasn't scooterbob saying that the dealers don;t have the exspensive diagnostic reader to read the codes, reset the cpu and/or reload as its not necessary as they should be able to analyze the problem and if they are having problems beyond their expertise they can call CMW who will work with them in analyzing the problem if its cpu related...i'm just spouting here but i thought their was a short discussion on the subject....its not like they can't put a new cpu if thats the culprit..
