Parking is tight
31 Guests, 0 Users
February 11, 2016, 02:57:58 am
Author Topic: Head pipe rattling loud  (Read 2393 times)
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Re: Head pipe rattling loud
« Reply #15 on: April 12, 2011, 05:18:12 pm »
Is it hitting the brake lever? Mine did. There is  a set screw for the brake lever. Guess not..
On a side note, I also I had a nasty rattle coming from the front and it turned out to be the forward bolt that holds on the tank. It was loose!! I used some rubber up under the tank while I was at it and its been silent.
jjoe256
« Reply #16 on: April 12, 2011, 07:36:56 pm »
Found out today the head pipe will be covered under warranty. Unfortunately CMW doesn't have any and has to get them shipped in from RE India.
Don't hold your breath.
« Reply #17 on: April 12, 2011, 07:48:33 pm »
isn't it the catalytic converter in there that has a spot weld broken...if so can't they just redo the spot weld...
jjoe256
« Reply #18 on: April 12, 2011, 08:16:02 pm »
If it's like mine, its the headpipe in the vertical section.
Chris-G5
« Reply #19 on: April 12, 2011, 08:19:51 pm »
Yeah, I'm still waiting. I hope I don't have to wait 5 months like you did for your replacement head pipe!!!
« Reply #20 on: April 13, 2011, 10:20:48 am »
i have to go out and look at my oem header pipe that been layed up for 4 years..i thought when i replaced it, their was what look like a small internal cat in there that the brit header pipe didn;t have..the brit style pipe was just a open pipe with better chrome and no PAV connection...I'm probably wrong but I'll take a lookie later..
Chris-G5
« Reply #21 on: April 21, 2011, 01:37:44 pm »
Got my replacement head pipe today. The new pipe has a heat sink at the head which the original did not have. The chrome is not quite as good as the original. It's more like the wheels but a little shinier. At least I don't have that annoying loud rattle anymore.
« Last Edit: April 21, 2011, 01:45:39 pm by Chris-G5 »
« Reply #22 on: April 21, 2011, 02:23:19 pm »
Looks good, glad you got it taken care of.
« Reply #23 on: April 21, 2011, 03:48:11 pm »
It looks quite good and so does your bike !
Your front tyre looks different from what I have on my G5.  What is the front tyre ?  Any special reason for changing ?
Chris-G5
« Reply #24 on: April 21, 2011, 04:08:28 pm »
Thanks
I just recently replaced my original tires with a set of 3.50 x 19 Dunlop K70s. I wanted to try a tire that has better grip on loose surfaces (gravel roads) and had a more round profile on the rear. These K70s definitely make the bike handle better, more nimble. Unfortunately I hear they don't last that long, wear fast, as they are made of a softer rubber for better grip. I'll see how many miles I get out of them.
jjoe256
« Reply #25 on: April 21, 2011, 05:17:44 pm »
Damn, my boat must have come in! You got that quick! What's your mpg with that exhaust? Looks good. I have a similar one but not as long.
Chris-G5
« Reply #26 on: April 21, 2011, 06:07:21 pm »
I haven't checked my MPG lately. Last time I checked, I had this silencer on, it was around 75 MPG. I'll have to check now that I have the 18 tooth.
It's this inexpensive silencer from Bulletwala (India)
http://cgi.ebay.com/ebaymotors/CHROME-ROYAL-ENFIELD-500cc-ELECTRA-SILENCER-ASSLY-NEW-_W0QQcmdZViewItemQQhashZitem20b893b90fQQitemZ140535642383QQptZMotorcyclesQ5fPartsQ5fAccessories
