I am going through my transmission as part of my Fireball build and I notice that the large gear that rides against the large countershaft bearing races has been running up against the transmission housing, not a lot but enough to make glitter in my transmission fluid. There is no thrust washer here to space the gear away from the bearing, nor is there one shown in the parts diagrams so I assume that my cases were machined a little too deep. I am thinking the best way to correct this is to either install a thrust washer/shim between the bearing and gear or to shim out the bearing either by dimpling the vertical seating surface of the case that the bearing seats against with a centerpunch or by installing an actual shim between the case and the bearing. Any thoughts? anyone come across this before?
Thanks,
Roger
