Ok, had to start somewhere. I dropped the main jet from 140 to 136 & left the pilot jet at 19 ( it's the leanest one I have). I'll run a tank at this setting and then drop to the 132, that's the leanest main I own, and check again. Then I'll start on the needle position. The higher the notch on the needle the leaner it gets ,right? High notch/lean-low notch/rich? Oh, by the way thanks for the help, Joe
