STD 350cc
May 25, 2016, 03:49:05 pm
Author Topic: Soliciting tips on mold removal  (Read 2088 times)
« on: March 21, 2011, 08:36:17 pm »
Need to kill and remove/prevent mold in a car interior and looking to the collective wisdom of the brotherhood for tips.
I would like to kill the stuff permanently.
 A neighbor does asbestos abatement and is willing to let me use the decon bay at his shop if i like.
What say ye oh hive mind ?
UncleErnie
Re: Soliciting tips on mold removal
« Reply #1 on: March 21, 2011, 10:45:46 pm »
The only thing I know of is bleach and a scrub brush.
When I first moved to the South, I was shocked to find all my leather stuff covered in grey flocking.  A lot of it didn't make it...
Run what ya brung
Lahti35
  • Currently Enfield-less!
  • The Department of Redundancy Deptartment.
« Reply #2 on: March 21, 2011, 11:07:39 pm »
I'll second that, works great on my basement walls.... probably not so much on your upholstry ???
'03 Ex-Electric start 500....gone but not forgotten...
I'm a fuel injected suicide machine. I am the rocker, I am the roller, I am the out-of-controller!
bob bezin
  • I ride therefore I am.
« Reply #3 on: March 22, 2011, 12:55:00 am »
you must dilute that bleach right??
2015 indian chief vintage
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
« Reply #4 on: March 22, 2011, 05:22:11 am »
Mold must be mechanically removed - you can't kill the spores with anything that won't kill YOU. I have fought mold in a car interior (and on some military surplus goods) and the best thing is just to get a carpet extractor and some Woolite (for the pleasant smell and do it about ten times in a row with ALL the upholstery, etc, exposed, until you can stand it. Dry thoroughly between extractions with fans. Mildew CAN be killed with mild bleach as it is more of a "plant" - but the mechanical removal here is the best deal as well. Good luck to you - you are in for a fight ....
elmagnifico
« Reply #5 on: March 22, 2011, 05:37:17 am »
you probably have water getting in somewhere like from a leaky windshield gasket. you have to get rid of the moisture.
2003 bullet deluxe
Lahti35
« Reply #6 on: March 22, 2011, 07:24:48 am »
Don't forget to wear some kind of breathing filter.....mold can make you very sick! No joke. people say its just mold but it can do some crazy stuff to you!
« Reply #7 on: March 22, 2011, 08:46:46 am »
Thanks for THAT!! You are very, very correct here ..... black mold (Stachybotrys chartarum) is the leading cause of respiratory problems related to mold in this country. It's not to be taken lightly.
Lahti35
« Reply #8 on: March 22, 2011, 10:34:06 am »
Yes sir, I had a basement full of that crap. Scrubbed the walls twice with a 15% bleach solution and so far it hasn't come back. I found that the basement was leaking under the old wood floor and pooling water....damp, humid, and dark...a perfect breeding ground :P
1 Thump
« Reply #9 on: March 22, 2011, 11:01:20 am »
Can diluted bleach affect the leather (color, finish etc.)
« Reply #10 on: March 22, 2011, 02:49:39 pm »
Bleach will SMOKE your leather! Scrub it only with saddle soap or other oil-based soap and VACUUM it dry to mechanically remove the mold. Repeat and treat as needed with conditioners to keep the leather from drying out. Leather is the most difficult to treat for mold because what gets rid of the mold often gets rid of the leather ..... Leather is the PERFECT breeding ground for mold if it's damp or dark ..... it's almost as good as your wet wood in your house, Lahti35!
mdobson
« Reply #11 on: March 22, 2011, 04:25:42 pm »
I don't know about upholstery, but Lysol is cheap and works as good as any commercially available mold remover on auto air conditioning systems here in humid Oklahoma. I imagine it would work as well on polyester auto carpet. With leather, try whatever you decide on an inconspicuous spot first...
mikail gransee
« Reply #12 on: March 22, 2011, 05:06:01 pm »
Mold is a living organism so like anything; take away one of the things that helps it to live and vacuum up the dry remains. Bleech is good, heat/dry environment is as well. I have seen little dehumidifiers that one can put in their car/home to rid mold. ;)
« Last Edit: March 24, 2011, 03:22:56 pm by mikail gransee »
-"ONCE YOU STOP CONTRIBUTING, YOU BEGIN TO DIE",   -ELENOR ROOSEVELT
1999 Enfield Bullet
1977 Yamaha xs360 TD
1978 Yamaha xs 400 D
2005 Yamaha YZF 600R
2007 Honda CBR 1000RR
« Reply #13 on: March 22, 2011, 07:20:11 pm »
yeah i remember getting my ford escort back from India and someone had left the window open and rain got in..then the windows were closed and it was put in a sea container and all that heat/humidity pretty much set up shop...upon arrrival, it was a mess....car was totaled as mold had found its way in every nook n cranny...even the plastic....those new Orleans cars were on the market cheap too...i was told depending how bad, its best just to total the car and move on...u don't want to breathing that stuff or expose kid to it as it can create some serious breathing issues...
« Reply #14 on: March 24, 2011, 02:18:55 am »
A broken passenger window let the rain in.
Thanks for the tips fellas.
