You probably are from the East Coast or the South.
The bike on the t-shirt is a California model.
Our headlights are skewed a bit to compinsate for the Geological shelf plate differance we have at the San Andreas fault line.
Our roads are all off camber no matter what side of the road you ride on to make up for the roads being slightly off kiilter.
If you see a rental car that came from Cali, you'll see that the drivers side (left) of all four tires are worn a bit more than the right side.
Sadly, when the bikes are uncrated they are in the neutral posistion and the tech's have to use a tool from RE called the Scoot-plumb-bob to set the light at the correct axis and refraction.
That's why the Cali. bikes cost a couple hundred bucks more as you'll see on the Motherships website.
Good pick up tho.
